AirPort Antenna
4 Answers 2 Score |
Spilled Coffee on Keyboard and Laptop Not Powering On |
8 Answers 5 Score |
battery won't charge up, no green lights |
17 Answers 30 Score |
New replacement battery for MacBook Pro not recognised |
10 Answers 9 Score |
RAM 16GB Upgrade Troubleshooting |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A1278 (EMC 2351 MacBookPro7,1) 2.4 GHz, A1278 (EMC 2351 MacBookPro7,1) 2.66 GHz
Troubleshooting
Track down a number of hardware problems using the MacBook Pro 13" Unibody Troubleshooting Guide.
Upgrades
There are a number of components in the MacBook Pro 13" Unibody that can be cost effectively upgraded.
- Memory: The MacBook Pro 13" Unibody Mid 2010 comes with 4 GB RAM standard, and accepts a maximum of 8 GB. If your MacBook Pro is still running with only the stock RAM, upgrading will provide a dramatic performance boost. You can upgrade to two 4 GB chips for a total of 8 GB very easily.
- Hard Drive: 250, 320 or 500 GB hard drives (or 128GB, 256GB, or 512GB SSDs) came standard with the MacBook Pro 13" Unibody. You can easily upgrade the drive to 750 GB.
- Battery: The battery is certainly replaceable, even though Apple doesn't consider it to be "user serviceable." Unscrew twelve screws, unplug the battery connector, and the battery can be removed!
Identification and Background
The MacBook Pro 13" Unibody is clearly differentiated from other MacBook Pros by its smaller size. However, it does resemble its larger siblings, the MacBook Pro 15" Unibody and the MacBook Pro 17" Unibody.
Use the laptop identification system to help you identify your machine. MacBook Pros tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
Tech Specs
Display:
- 13.3-inch (diagonal) LED-backlit glossy widescreen display with support for millions of colors
Storage:
- 250GB, 320GB or 500GB hard drive, or 128GB, 256GB, or 512GB SSD
- 8x DVD/CD slot-loading SuperDrive
Processor:
- 2.4GHz or 2.66GHz Intel Core 2 Duo processor with 3MB on-chip shared L2 cache
Memory:
- 4GB or 8GB of 1066MHz DDR3 memory
Wireless Connectivity:
- 802.11n Wi-Fi wireless networking ; IEEE 802.11a/b/g compatible
- Bluetooth 2.1 wireless technology
Graphics and video:
- NVIDIA GeForce 320M graphics processor
- iSight camera
- Mini DisplayPort
Ports:
- MagSafe power port
- Gigabit Ethernet port
- One FireWire 800 port (up to 800 Mbps)
- Mini DisplayPort
- Two USB 2.0 ports (up to 480 Mbps)
- SD card slot
- Audio in/out
- Kensington lock slot
Audio:
- Stereo speakers with subwoofers
- Omnidirectional microphone
- Combined headphone/line in (supports digital output)
- Support for Apple iPhone headset with microphone
Battery and power:
- Up to 10 hours wireless productivity
- Built-in 63.5-watt-hour lithium-polymer battery
- 60W MagSafe Power Adapter with cable management system
What’s in the box:
- MacBook Pro
- Display cleaning cloth
- 60W MagSafe Power Adapter, AC wall plug, and power cord
- Software DVDs
- Printed and electronic documentation
